caliper bleed screw !! #%&@!!!!!
Ive been going back and forward all weekend with the morons at the parts counter. Im trying to replace my caliper bleed screws with a new set as mine are slightly stripped.
I understand that HD comes out with new part #'s that replace older part #s etc...
The bleed screw on my 08 Night Train, as well as 99% of the other bikes Ive looked at have the same bleed screws unless they've been replaced with a different one.
My bleed screws are completely different from what the dealer is saying is the new part #.
Mine has what looks to be two hex areas One which you use to loosen or tighten the bleed screw and the other seems to be a guide/stopper so that it wont go in any further than that point. Which has And also an o ring. aswell
The one they are giving me is threaded all the way through and does not have a stopper section, nor does it have an o ring. If that makes any sense ???
The part # they have now is 44048-83A Which means that they have been using the same part since 1983, until the change was made to letter A. All the 2010 models on the show room floor are using the same ones as on my 08.
Based on my past history with HD part #'s. the last 2 numbers are usually the year that those part numbers are from and used. If a letter follows, it means that some type of small adjustment or change has been made. Nothing major or it would have a complete new #.
Does anyone have access to a different part # ???
Fits 84-up all FLT, SoftailŽ, and Dyna™ all models. Fits 84 FXST, FXSTC; 85-86 FXEF, FXWG, FXSB all models
http://www.hmhd.com/webstore/viewite...pname=viewprod
