Fatboy Auxilary Lighting
The difference that I could see is all cosmetic. The lower priced unit is a round bar, where the higher priced unit has a more streamlined bar that is sort of oval shaped (wider front to back, and narrower from top to bottom).
That's the only difference that I could see.
Hope this helps.
The standard kit is what is found on the Heritage and the Deluxe Kit is what is on the Deluxe. IMO the Deluxe kit looks a little more custom, the shape of the cross bar and the mounting looks is thicker and looks more custom than the standard kit..
yes you can wire the Spots to work with the High beams on , do a search there are some threads on it or you can just connect direcrly to any switched hot lead or directly to the battery (down side of that is if you dont remember to turn off the spots it will drain the battery.
Wired mine up with a relay so they can be on with both hi or low beams. Dont have to worry about leaving them on with a relay.
Here is a good deal since it has turn signals. This person is over an hour away from me. I do not know him. If he lived closer I would check it out for you. Heck, Id probably buy it just for a spare.
http://sacramento.craigslist.org/mcy/1577066447.html
The more expensive kit is what I have on my bike. As stated it has an oval shaped bar, bullet style signals, and smooth tins. Also be aware of the differences if you intend to mount a shield. Certain aux. light kits will not work with certain shields. Hope this helps.
