gator gat a 2" lift on tank too
yours stock? im sure you can get braided,if yer doin that
id totally 86 the line and run it through under tank
the rocker & deuce fuel tank is longer than other softails, so the fuel line is longer...on the deuce it's 10.25" long from fitting to fitting, others are like 2" shorter (i could get the exact shorter measurement tomorrow)...
you should take off yours and measure it before buying a new one, but i'm quite sure it will be 10.25"
I did use the Dyna Fuel line Part number 63709-04 on my Fatboy. My bike is EFI. It is the pressurized line, not the crossover on the front of the tank. It comes complete with the snap fittings on both side. Simple remove and replace. Works great!!
The number you listed is a crossover line. The Dyna EFI fuel line part# is 63020-04.
