Leak
Leak
Fired up the bike today first time since November.
Went out about an hour after i shut it off and spotted a leak puddle under the primary. About the size of a quarter. Pink fluid as in Transmission. Apperas to be coming from between the primary and the tranny? I have to stick my finger way up under and behind the primary to feel it. Its slimy back under there.
Is there a vent tube back in there? Or a seal?
Fired it up again for about 5 mins and only got a drop accumulated on the primary in drain plug area.
Any ideas?
Any ideas?
Mine did just about the same thing this year, it sat for a month and when I rode it over christmas I had the same leak. It's gonna be either a mainshaft seal-(maybe with a loose pully) or a shifter shaft seal. I have not taken it apart yet but read through this thread, it explained enough so I understand it now..
https://www.hdforums.com/forum/evo-c...uestion-2.html
Doug
Doug
Doug
Doug
I have not ran mine since then, way too cold and salt on the roads. Mine only seems to leak when it's running, I looked under it the other day and not a drop on the floor.
With the Holidays, deer hunting and cold garage, I have not really looked at it. I'll have it on the lift soon to get a good look at where it's comming from, supposed to warm up for the next couple weeks.
Doug
Doug
Thing about it this was not fresh fluid. It was contaminated w/ moisture. Kinda pale and slightly gel like. Like it had been sitting up in a pocket somewhere all winter? I know the tranny fluid was replaced the beginning of November a week or so before i knew it would get covered.
I'm taking it to Florida February 6 so i guess I'll know alot more then? Hopefully i dont find myself Dealered up for a day because of a huge leak.
500 bux?
500 bux?
That being the case if I drain the primary I should detect it since I run HD 20/50 and its clear. Right?
If i drain the primary and theres no red in it this more than likely was fluke or a vent tube maybe?
Actually its Belray.
