Le Pera Barebones
Yea I guess it not only going to be to narrow, but won't mount to my bike either. I was really hoping it would fit.
apologies if i'm being thick... can anyone explain how the fender-mounted BBones mounts to the 07 heritage? I've got a 2-bolt bracket where the stock seat's mounting plate attaches. Do I need to remove that bracket all together or does the seat go on top of those bolts? Can someone comment on how easy is it to switch between the stock seat and BBones?
1 Post
Just drop everything through the fender. Hope this helps you.
Steve
Not sure but do you mean that your BB seat attaches to the frame where those plugs were? I was gonna order a Lepera and they told me it would attach to my frame. You can see the holes in the pic in the above post. If so, you need to remove the whole OEM bracket and bolts. (If not, ignore my entire post...lol) I have an 07 Heritage and I had to remove those rear bolts that hold the driver seat on cause they sent me a Mustang seat that attaches to the frame and doesn't use the OEM equipment. I actually like it better as the seat fits real nice and secure. I like the frame attachment much better.
Steve
Steve
Yes thats right... Mine is a 05 and it bolts to the frame... Not sure about the newer ones though. I think they bolt up with a thumb screw at the rear of the seat... Heres a link you can check for yourself...
http://www.lepera.com/
