Pulley Cover
I did mine when I first got my bike. I had no knowledge of how to do it. I did it in about 2.5 Hours. I could do one now in about 1.25 hours. Just pull the axle and then take an air gun to take off the pulley bolts and a torque wrench to reinstall with blue loctite, make sure you blue loctite. Also go ahead and get the chrome bolts also or the chroome caps that go over your stock bolts to enhance the chrome cover even more. Make sure that the bolts you get, if you go that way are the identical length, not shorter or longer. If your exaust is in the way of the axle shaft being pulled (on right) you may have to pull the mufflers (stock pipes) or the header pipes off (aftermarket headers). Also check how your belt tension is right now, and remember how much play it has, so you will know when you tension it back. Also go ahead and get a polished rotor ($139.00 at Harley) while you got the axle pulled, you know you will do it in a few more months , so do it now and save the hassle.
It's way easier now. When I put mine on my '90 FXSTC, you had to 'dish' the threads on the wheel with a drill and put in studs for chrome acorn nuts. Man was I nervous to do this on a new bike, but that's what they had to mount it with and that's what the instructions said. Wifey thought I was absolutely krazy.
Count the treads on the axle adjuster bolts and make them the same on each side each side is all you need to do. Count them before tear down and this will help you going back. Count the threads from the bolt head towards the rear is easier. Here is a high dollar axle adjuster ,but still almost the same as yours. Look at this link to get an idea of what the adjuster bolt looks like.
http://www.harley-davidson.com/gma/g...5&default=none
X
