Progressive 422 install Loctite or No?
I have read several posts on here of guys installing these without using the special Snap-on tool. Did that, but I also see posts saying to make sure and use red loctite on the bolts. The instructions and even the service manual don't say anything about using loctite. Is this only for the reason the special tool was not used to accuratley tighten the bolts?
regards,
Dale
Only used loctite on the bolts that hold the 422 shocks to the swingarm. You will need to adjust the front bolts to raise and lower the bike and they jam nut togeather and reqire really no loctite. I use blue loctite, instead of red. The blue will hold good enough, and the red is to hard to break back loose if you want to take it apart again in the future. You do not need the snap on tool to change out shocks, I used a 3/4 inch box end hand wrench, I then locked another hand wrench to it by putting a second box end on the open end of the wrench on the shock bolt, this gives me a longer wrench and leverage (Old Mechanics trick). The bolt when going back gets loctite and the old 2 or 3 grunt method, on large bolts I hardly ever use a torque wrench. Heres my post from last week, see the pics of the 422's in the first post.
https://www.hdforums.com/forum/softa...-pictures.html
Good. I used blue loctite and beat it with a sledge a couple of times. When I removed the stockers I was surprised they weren't as tight as most people say. There was no trace of any loctite at all on either end. Didn't want to use red either as with the bushings on the shocks using heat is not an option for removal if I ever had to remove them. Thanks fellas. Hope these suckers ride as good as they look. Got springs for the front as well so I'll probably have more questions later.
2009, 422, black, bolts, breaking, fatboy, heritage, install, installation, instructions, motorcycle, progressive, shock, shocks, softail
