2005 Fatboy Neck. Where's the Zerk?
12-24-2009, 06:51 PM
I got a little squeak in my turn and for the life of me cannot find the Zirk to give it some grease. Is there one? How do you lube the 2005 FLSTFI neck? Thanks in advance.
12-24-2009, 06:53 PM
I dont know on yours, but the zerk on my 06 is justr above the neck lock on the righ of the bike. Hope this helps.
12-24-2009, 08:21 PM
Right side of the steering neck. A small silver zerk. Take off that neck cover and it should be under there. Take a picture of the right side and post it, I'll PS it for you.
12-24-2009, 09:46 PM
I have a 2005 SE Fat Boy and there is no way you can miss the Zerk fitting. As stated in a previous post it is approximately 1" above the fork lock.
12-24-2009, 09:48 PM
If it has never been greased, it will take the better part of a tube of grease, before you see it oozing out at the top.
Tom
12-25-2009, 05:10 AM
Quote:
Originally Posted by
HarleyGoodies
same here, cept there is no cover on it,, just there, both of my sons is the same..
12-25-2009, 06:39 AM
Zerk? someone call my name?
12-25-2009, 10:37 AM
careful about putting too much grease in there as it will also spew all over the fender after riding all day and getting hot.
12-25-2009, 12:21 PM
SEDELUXE
If you don't put enough grease in to ooze out by the top bearing, your wasting your time. The top bearing will not get any grease.
Tom
1Bad70Charger
01-31-2008 05:33 AM
deansoldit
06-07-2007 04:50 PM
cajunman831
10-17-2006 08:11 AM
Snoman
03-21-2006 01:06 AM
tizone
Motorcycles For Sale
06-11-2005 06:19 PM
