xbones headlight part number
Yup is 5 3/4 inch
Just looked in my parts manual ... got to say, very confusing and lots of little parts ... maybe better go by dealer and sort it out there.
Can give you the numbers (USA Model) marked out for the Xbones (JM and ALL in parts manual), but you will need a service manual to put it all together!
Use these numbers at your own risk!, I might have made typos and some numbers might cover more items, so their could be "repeat" parts in here.
index number - Part number - Description
01 - 3214 - Screw
04 - 4350A - Screw
10 - 6379W - Washer (2)
12 - 7073 - Lockwasher (3)
14 - 7230 - Lockwasher (3 (6-JM))
15 - 7606 - Locknut
16 - 7680W - Acorn nut
18 - 7716 - Locknut (3-JM)
21 - 9847 - Wire Terminal, female spade, right hand
21 - 9848 - Wire Terminal, female spade, left hand (2)
22 - 10065 - Cable strap
26 - 67667-05 - Medallion, lens
30 - 67769-93 - Adapter ring
32 - 69925-08 - Bezel Ring (black)
34 - 67938-08 - Mounting block
37 - 68297-05 - Reflector Assembly, 5-3/4 in.
38 - 68329-03 - Bulb, HB2/H4
40 - 68380-05 - Boot
44 - 69609-00 - Bumper, rubber
48 - 69923-08 - Shell assembly, 5-3/4 in. (black)
49 - 72056-92 - Insulator, spade terminal, 3-way
52 - 73154-96BK - Housing, 4-place socket
54 - 73191-96 - Terminal, socket, #16-20 AWG (4)
48 might be shell and wires
37 could be part 40 - 38 - 26
Hard to make out from the parts book, they got all the headlights on one page so lots of parts and lots of numbers and lines going every which way
Hope it helps!
01 - 3214 - Screw
04 - 4350A - Screw
15 - 7606 - Locknut
Hope it helps!
chicagoavatar
06-08-2009 07:07 AM
