pm 240 phat tail
phatail:
The PM Phatail Kit consists of:
1) Wide Swingarm (black powdercoated)
2) Rear Axle with Billet End Caps
3) Steel Fender
4) Billet Aluminum Fender Struts
5) Billet Primary Spacers
6) Trans Mainshaft
7) Countershaft 5th Gear
8) Final Drive Gear
9) Front Motor Sprocket
10) Clutch Push Rod
11) All Trans Gaskets
12) All related Hardware and spacers
13) Detailed Instructions
14) (99 & lower includes new belt)
Heartland:
Heartland TWO-FIVE-O kit:
1)struts
2)fender
3)seat
4)rock guard
5)swing arm
6)1” primary and transmission mainshaft offset kit
Two-Five-O Conversions
1986-2008
Four 11 inch fenders to choose from; fender is not pre-drilled and shipped unpainted.
Solo Seat covered in Leather with Vinyl side bands comes with this conversion.
Struts are slotted and pinned for application of our second seats.
18 x 8.5 60 Spoke rear wheel with appropriate offset and Avon Tire is available for this conversion.
18 x 8.5 Chrome Solid rear wheel with appropriate offset and Avon Tire is available for this conversion.
Frame Horns must be removed. Horn cut template is provided.
Kit includes: Struts, Fender, Solo Seat, Rock Guard Fender, Swing Arm and Transmission offset kit
Accessories available include: Second Seat, Ride, Rack & Rest, Gear Bag, Plate Holders, Foot Pegs, Signal
Mirrors and Billet-Tears
How to order: Choose your Fender and your Swing Arm finish Raw, Black or Chrome
the way I figure it, hangin a fat tire on the rear of your softail using one of these kits is a $5000+ deal.
once you buy the kit, a rim, tire, pay for paint/powder-coating/chrome and pay the mechanic to install the tranny shafts. youre into it for atleast 5 G's and thats assuming that I'm/you're doing all the work (less the tranny work)
it looks kickazz when its done but thats one hell of a price tag just to get a fat azz.
My biggest gripe was not enough research before purchasing.
If I had, I would've went for the Heartland for the available options with luggage racks, extra seat, etc...that in itself was worth the extra $$$$!
I've even bought an extra set of used PM fender struts so I can copy them to make my own to replicate the Heartlands so that I could use one of their optional seat set-ups for 2 up.
Heartland uses a beefier sized set of struts because they slot them to allow for their optional stuff to mount to.
Real nice when your traveling and packing up, then once arriving you can easily take off the seat/rack.
Again, that is my 2 cents on these 2.
I have a 240 PM Phatail kit and have no complaints on the quality. Heartland does give some add'l options on seating/luggage which is nice if thats important to you.
I have no regrets about going with PM.
Continue to check in the classified area on this board cause there was 1 available awhile back I believe at a decent discount. Seems when you want a unique part thats the only time there isn't a stray available at a discount price. If you are patient the right one will pop up.
yes, there are definite similarities in the kits.
phatail:
3) Steel Fender
6) Trans Mainshaft
8) Final Drive Gear
10) Clutch Push Rod
Heartland:
1)struts
2)fender
3)seat
4)rock guard
5)swing arm
1986-2008
phatail:
3) Steel Fender
6) Trans Mainshaft
8) Final Drive Gear
10) Clutch Push Rod
Heartland:
1)struts
2)fender
3)seat
4)rock guard
5)swing arm
1986-2008
yeah, heartland wants (retail) $3399 for the 250 kit, so i guess i'll start looking more assertively at the classifieds here and egay
