V&H True Dual - Year Difference?
Old 12-03-2009 | 10:21 AM
Mike NY's Avatar
Mike NY
Default V&H True Dual - Year Difference?
So I'm thinking about a set of True Duals for my 06 Deluxe. I see that there is a version for 06 models and below and then a version for 07 and above. I know that 07 has the O2 sensors.
Is that the only difference? Would I be able to install an 07 set on my 06 and just plug the sensor wholes on the exhaust? Are there any fitment issues?
The reason I ask is I can get an 07 set $100 cheaper than an 06 set.
Thanks guys..
Mike
NY
Old 12-04-2009 | 10:05 PM
JoeFLHX's Avatar
JoeFLHX
Yes they fit.
Old 12-04-2009 | 10:43 PM
oct1949's Avatar
oct1949
usually the other way around..
Old 12-05-2009 | 10:26 AM
Big Smooth's Avatar
Big Smooth
I believe the O2 sensors are the main difference. I know a lot of companies simply provide plugs for the sensors to make the pipes compatible with older models. The V&H True Duals are very nice and will go well with your apes. I would have gotten them if it weren't for my desire to have fishtails. As such, I went with Samsons as I feel that Stevie Wonder must have designed the V&H fishtail tips. Another advantage of the V&H duals is that you don't have to switch out your shift linkage if you took the time to get a nice one. With Samson's, the left pipe comes out too low and they provide you with an angled linkage to bypass the pipe.
Old 12-05-2009 | 06:23 PM
Mike NY's Avatar
Mike NY
Thanks for the responses guys. I figured as much that they would fit but wasn't exactly sure if there was a Head Pipe size difference in any way.
They should just offer one model and throw the Plugs in the box.
Mike
NY
kmayHD
10-17-2012 08:20 PM
mrjharley
07-17-2009 03:30 PM
strich
Exhaust System Topics
04-08-2009 09:54 AM
achog88
07-13-2008 03:50 PM
rel22
02-18-2008 05:45 PM
Quick Reply: V&H True Dual - Year Difference?
