Cutting Deuce license bracket?
Old 11-24-2009, 03:55 PM
Dieselhed's Avatar
Dieselhed
Dieselhed is offline
Default Cutting Deuce license bracket?
Going to a side mount plate. For the guys that have done it, how did you do it? I would take the rear bracket completely out but I'm worried about the tail light harness rubbing on the tire. Any ideas?
Old 11-24-2009, 04:18 PM
FL DEUCE's Avatar
FL DEUCE
FL DEUCE is offline
I did it when I had the stock fender. If I remember right I traced the plate with a white marker and then used a hacksaw to cut the plastic. When you trace the plate move the plate to the right and then cut it. If you don't the plate will look off-center.
Old 11-24-2009, 05:11 PM
Dieselhed's Avatar
Dieselhed
Could you see what was left over handing down?
Old 11-24-2009, 05:16 PM
Dieselhed's Avatar
Dieselhed
Oh yeah, I've got the fancy chrome bracket.
Old 11-24-2009, 06:45 PM
FL DEUCE's Avatar
FL DEUCE
FL DEUCE is offline
Place the plate frame on the plastic part and cut it off after you trace it. I put the frame as far up on the plastic as I could.
Old 11-25-2009, 06:08 AM
Dieselhed's Avatar
Dieselhed
I've got the chrome 1 piece bracket. This thing is huge! Or was, I cut it last night. That's some thick stuff as I went through 2 cut off wheels.
Old 11-25-2009, 11:21 AM
mstakern's Avatar
mstakern
mstakern is offline
Let's see what the finished product looks like!!
Old 11-25-2009, 11:28 AM
flibuoy's Avatar
flibuoy
flibuoy is offline
Smile
One of the first things I did when I got my '05. I used a jigsaw. Small,almost unnoticeable improvement...what you do benefit from is NOT noticing the mount as much.
Old 11-26-2009, 09:54 AM
Dieselhed's Avatar
Dieselhed
This thing could not be cut with a jigsaw. I went through 2 cut off wheels with it using air. This was not the stock plastic mount. Got everything on and it looks pretty damn sexy! Anybody wanna buy a Lava Red Sunglo paint set?
Old 11-26-2009, 10:11 AM
Rockyriver's Avatar
Rockyriver
Rockyriver is offline
Lets see some pics of the finished tag mount. Please !!!!
Quick Reply: Cutting Deuce license bracket?
