Handle bar ?
Old 11-24-2009, 10:45 AM
06DEUCE's Avatar
06DEUCE
06DEUCE is offline
Default Handle bar ?
My dad has a 97 fxstc with the buck horn style bars. he has been saying for years that he wants to get the new style bars that come stock on the new softail custom. well I think I might get them for him for xmas. anyone know what i'll need for the swap? I would think the cables should be fine? will the newer bars fit or are they bigger in dia ?
Old 11-24-2009, 02:00 PM
eddyp's Avatar
eddyp
eddyp is offline
Very easy swap, I did this to my FXST. It makes the bike more comfortable to ride. You just need the bars and risers. My standard cable were just about long enough.
Once he has swapped he will never go back to the standard bars
Old 11-24-2009, 10:00 PM
dpd1983's Avatar
dpd1983
dpd1983 is offline
Yea this should be no prob for you me and my buddie just changed out a set of beach bars on a t-sport to a set of 12" t-bars lol the cables were just alittle to short but thats a big change!!!! You will be fine!!!!!!
Old 11-25-2009, 06:17 AM
06DEUCE's Avatar
06DEUCE
06DEUCE is offline
So, the bars are bigger in dia thus the reason for the new risers? is there a aftermaket bar that is similiar and is the same dia as the older bars. anyone know the 97 fxstc bar dia ? 7/8 if i had to guess.
thanks for the help!
Old 11-25-2009, 07:11 AM
twisted125's Avatar
twisted125
twisted125 is offline
Hey man, my 07 standard is torn apart right now. I did the bars just like a custom. I am putting on shorter risers and taller bars and have those other bars and risers just set aside. I was going to put them on ebay. The risers are around a 4" or so with a little pull back, and the bars are 10" mini apes. Theyre in great condition. you would have everything you need except for the bolts coming up through the bottom of the risers (should be able to use his). Top clamp, bolts etc are all there. May want to get him a set of cheap poly bushings though, prevent that bar sway. I got mine from Hill Country Customs for 8 bucks. Someone correct me if my risers would not work for a 97. They are 1" bars and risers.
LH's Avatar
LH
LH is offline
Bars are the same dia. You need the shorter risers to use the same cables.
Old 11-25-2009, 07:14 AM
twisted125's Avatar
twisted125
My standard came stock with the 4 inch pull backs and buckhorns. I was able to put the mini apes on and not have to lengthen anything.
Old 11-27-2009, 07:35 AM
06DEUCE's Avatar
06DEUCE
06DEUCE is offline
I'm gonna stop in @ my local dealer and ask the parts guru and let you know. thanks
Old 11-27-2009, 07:39 AM
twisted125's Avatar
twisted125
cool, their not goin anywhere. They are the stock risers from a 2007 standard. Bars are 10"mini apes. You can see pics on my profile. - their chrome, my sig below was photoshopped.
Old 11-29-2009, 12:50 PM
06DEUCE's Avatar
06DEUCE
06DEUCE is offline
well, i stopped by the dealer to look at a new custom. they have a very low riser maybe 1" or so. my dads 97 has about a 4" riser. also I would have to replace the metal brake line. so to copy the new custom i need a 1" riser, bars, and brake line. does that sound right?
Quick Reply: Handle bar ?
