I need a little education on this. I am doing some mods to the bike. Arlen Ness Big Sucker SS stage 2, PC-V, torque cones, and samson custom shop step true duals. The question is can I use the blue removable thread locker to keep O2 sensor plugs in?
Somebody correct me if I'm wrong but I believe the answer is no. The operating temperature for blue loctite is -65F to 300F and the exhaust will get much hotter than that. Just tighten it real good and it shouldn't go anywhere.
You're right. The high temp/high strength is good for 450 degrees. I wouldn't use anything either. If you expect you might want to remove the plugs someday I'd put antiseize thread sealant on them.
