Stabil in Gas Tank.Do You Run The Bike for 5 Minutes?
Old 11-18-2009 | 08:13 PM
Wallaby's Avatar
Wallaby
I do the stabil and let it run briefly, then top off with a fuel container at home.
Interestingly, I have not used Stabil in my snowmobile (carb) or my plow truck (injected) for the last 2 seasons, and they both fire right up when the snow flies?
Old 11-18-2009 | 08:24 PM
jason628's Avatar
jason628
Originally Posted by ord sgt
Pour some in the tank while topping off with fresh gas. It will get mixed in and into the injectors on the ride home. That way, you are one step ahead for winter. Or, you could skip the Sta-bil and just ride all winter,except when the snow is on the ground.
Greetings,
This is what I do...and hope the weather isn't too bad so I can ride!
Old 11-18-2009 | 08:28 PM
dennyo's Avatar
dennyo
----- Never , Heard , Of , Duh , Stuff
Old 11-18-2009 | 08:30 PM
2kids3pets's Avatar
2kids3pets
Should you run the carb dry or leave it full with fuel & Stabil
Old 11-18-2009 | 11:30 PM
WARG's Avatar
WARG
Top off the tank, put in the Stabil, ride home. All mixed and ready to sit. I ride all winter, but I travel for work and sometimes the bike sits for a few weeks at a time.
Old 11-19-2009 | 10:43 AM
Ruralmed's Avatar
Ruralmed
The 10% ethanol unleaded breaks down in about 10 days, so a fuel stabilizer is a great idea. I do just what you posted, fill er up and take for a short ride.
Old 11-19-2009 | 10:56 AM
tlb's Avatar
tlb
I would also add, if you are going to let it sit for awhile, fogging your cylinders.
I ride all year, but I winterize my boat, quad, mowers, ect. every year. I seem to have less problems over the years, since I made it a habit to add Stabil and fogging.
Old 11-19-2009 | 07:42 PM
Alain's Avatar
Alain
wha't fogging ?
Old 11-19-2009 | 07:52 PM
tlb's Avatar
tlb
you run fogging oil through the carb or squirt it in the cylinders to to lube cylinders.Fogging oil is an anticorrosive that will protect the internal surfaces of the carburetor and the cylinders
Old 11-19-2009 | 08:26 PM
Alain's Avatar
Alain
thanks for the clarification.
