Brake Fluid Question
Ok folks. I know you're going to recommend getting a manual. And I will.... but this evening I just bought a new/used Nightrain and the front brake feels very low on fluid and I need to get it road safe by tomorrow afternoon.
What brake fluid do I use and is it just like any other front brake reservoir where you pull off the cap, fill it up and re-seal it?
Yeah, it's just like other front brake reservoirs. I have a 2007 Night Train and the manual says to use DOT 4 brake fluid. The manual also says the fluid level should be 1/8 inch below the gasket surface.
I can't make any comments about whether this is why your brakes feel off though...
