200 REAR TIRE ON 06 DEUCE!?!?
Old 07-10-2006, 10:29 PM
deucn2's Avatar
deucn2
deucn2 is offline
Stage II
Default 200 REAR TIRE ON 06 DEUCE!?!?
hey, new to the site just bought a 06 deuce and was curuious about what would be involved in installing a 200 series rear tire?? any help would be appreciated......thanks.
Old 07-20-2006, 02:06 AM
choppertime's Avatar
choppertime
choppertime is offline
Default RE: 200 REAR TIRE ON 06 DEUCE!?!?
Despite what others will tell you, you can simply change the rear fender, buy a 5.5" wheel, space the pulley, machine your caliper down to .900 and grind a bit off the inside of the inner primary and you will be good to go. I have the calipers machined in chrome if you ever decide to do it.
Old 07-20-2006, 01:43 PM
deuce dude's Avatar
deuce dude
deuce dude is offline
its simple really, you can space the wheel over and keep your stock belt(its a tight fit though) or you can go to the 06 standard belt which is narrower and keep the stock spacers. both of these require anew 5.5 wheel. also, you can keep your stock fender by doing a few little mods to the strut mounts......mine has the 200 with stock fender and narrow belt.....works and looks great!!!
Old 07-20-2006, 01:44 PM
deuce dude's Avatar
deuce dude
hog-pro uses the narrow belt and dmcustoms uses the spacer method......
Old 07-20-2006, 01:45 PM
deuce dude's Avatar
deuce dude
oops..[:@]....[&:]
Old 04-26-2009, 10:14 PM
countrybros03's Avatar
countrybros03
countrybros03 is offline
Stage I
I WANT TO GO THE CHEAPEST WAY POSSIBLE AND PUT A 200MM ON MY 01 DEUCE IF THAT IS TO MUCH i WOULDN'T MIND A 180MM I JUST DONT WANT TO PAY A LOT TO HAVE THIS DONE
cruiser73
12-27-2020 06:33 PM
JMo
08-19-2016 07:05 AM
deuce06
02-25-2010 01:39 PM
softail99custom
12-09-2009 06:15 AM
Mr Wasabi
08-17-2008 03:48 PM
Quick Reply: 200 REAR TIRE ON 06 DEUCE!?!?
