Torque Wrench?
Old 07-09-2006, 09:30 PM
UltraBrian's Avatar
UltraBrian
UltraBrian is offline
Default Torque Wrench?
Anyone here have/use a Torque Wrench when customizing your ride? Take for instance I just replaced my Chain Inspection Cover. The instructions that came with the new cover states "Tighten screws to 50 - 80 in-lbs (5.6-9.0 Nm)" I'm guessing that I would have to use a Torque Wrench for this and use a Torx head for the screws itself. I have a Torx bit that attaches to my screwdriver and used that. Should I use a Torque Wrench? Does anyone here use a Torque Wrench when adjusting/replacing/adding parts to your rides?
Old 07-09-2006, 10:05 PM
softail2005's Avatar
softail2005
softail2005 is offline
Default RE: Torque Wrench?
Hi Brian
I have never used a torque wrench on any of my bike work and have never had a problem. I always used the blue locktite to insure that the bolts or screws stay seated. I think the torque spec are more important if you do work within the engine on moving parts. It will also prevent you from overtighting and striping in soft metals. I never work on the bike while its hot, the metal is softer if working on Alum, steel is not an issue.
I will catch a lot of flack with my response from the working mechanics. I have one of the old style torque wrenches from sears so I guess I could use it, not sure how accurate it is after 30 years, its the old style with the bar running the length of the wrench which "torques" as you twist or tighten the bolt.
I doubt if you can tighten bolts, screw very tight with only a screwdriver, need to use a rachet on them with reasonable pressure. In my humble opinion. Hope this helps
Old 07-09-2006, 11:12 PM
UltraBrian's Avatar
UltraBrian
Yea, it helps. I always appreciate other's advice/opinions. How I learn things and get experience. Thanks softail!
Old 07-09-2006, 11:57 PM
cjgrog's Avatar
cjgrog
cjgrog is offline
Brian-
The correct answer, technical aspects aside, is when they tell you you need a specific tool, it's a good reason to go out and spend more money and add to your tool collection, and be able to explain to the wife that it's all about safety!! Got an in-lb and ft-lb wrench at my local auto store for about $30 apiece.
CJ
Old 07-10-2006, 12:21 AM
UltraBrian's Avatar
UltraBrian
Good idea! Can always use another tool in the collection. Noticed you changed your Chain Inspection Cover, CJ. Did you use your Torque Wrench? Also, did you replace the Gasket?
Old 07-10-2006, 12:29 AM
20FXST06's Avatar
20FXST06
20FXST06 is offline
Brian, GET the wrench, so you won't have to say[sm=oopssign.gif]
Old 07-10-2006, 12:38 AM
UltraBrian's Avatar
UltraBrian
Wonder if Advanced Auto Parts carries torque wrenches? That's the only auto parts store chain around my area. Sears has them....for over $100 though.
Old 07-10-2006, 12:59 AM
blown alcohol's Avatar
blown alcohol
blown alcohol is offline
I use a torque wrench when I am changing the fluids. It only adds a couple minutes to the job, and I know everything is torqued to spec. I even torque the drain plugs. I have heard so many strip the torx screws in the inspection covers. So far I have not had any problems with the torx screws.
Old 07-10-2006, 10:01 AM
eunrein's Avatar
eunrein
eunrein is offline
Sears online has them for 64.99, the stores will match the price and you can order online and pick up at your local store. Advanced Auto Parts really is not much less expensive and definitely not of the same quality.
Craftsman Torque Wrench, 1/2 in. Drive
Sears item #00944595000 Mfr. model #44595
20 to 150 ft. lb. in 1 ft. lb. increments
Craftsman Torque Wrench, 3/8 in. Drive
Sears item #00944593000 Mfr. model #44593
25 to 250 in. lbs. in 1 in. lb. increments
Sears item #00944594000 Mfr. model #44594
10 to 75 ft. lb. in 0.5 ft. lb. increments
A good investment!
Old 07-10-2006, 12:08 PM
liltrk's Avatar
liltrk
liltrk is offline
Ever snapped off a bolt, or had that sickening feeling when something that was "almost tight" suddenly gets loose again? A $100.00 torque wrench seems really cheap at moments like that.
Quick Reply: Torque Wrench?
