PLEASE READ: How to bleed the brake properly, great discovery
I wrapped up my bike for winter storage yesterday, changed all the brake fluid while I put new brake pads in. When I bled the front brake, nightmare! I do have a shopvac bleeder, tried it for 15 mins, still spongy brake. Use gravity bleed, start getting a little but half way on the brake lever, driving me nuts. No matter what I've tried, no luck. Finally I discovered something, when you bleed the front brake, you usually turn the wheel hard to the left because of the reservoir overflow, correct? That's the problem, I looked at the caliper bleeder screw, when the wheel is cranked all the way to the left, the bleed screw isn't sitting at the top of the caliper, air could still be trapped in there. I ended up filling the reservoir, closed the lid, turn the wheel all the way to the right so the bleeder sat high, cracked the bleed open, see tons of bubbles coming out. Gravity bled again for 2 mins, brake was solid! I think a lot of ppl are having trouble bleeding the brake just because of this, give it a try! I guarantee it works. Alex
Try also with the bleeder valve closed snapping the front brake handgrip very quick and letting it sit a second and then snaping the front brake lever about ten times and repeat. This makes the air come up into the master cylinder. The first time I heard this I thought the guy was crazy, but I tried it when I put on steel braid brake lines last week and it worked.
