Pipe colouring
Old 11-02-2009 | 01:59 PM
frenchman's Avatar
frenchman
Default Pipe colouring
The pipe of my rear cylinder (TC 88 carbed, pipes are SE 2, newly installed AN big sucker) starts getting a kinda golden colour. Didn't notice that before, so I guess that's a brand new issue. Usually it means, the bike runs too lean (didn't rejet yet). But just the rear one? Isn't that a little odd? Any advice on how to get rid of that coloration?
Old 11-02-2009 | 02:04 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Sponsor
Rejet and get new pipes. There is something called Blue job which i supposed to to get rid of that, but I have no experience with it.
__________________
Old 11-02-2009 | 02:13 PM
DyNaBoB's Avatar
DyNaBoB
the rear one runs hotter then the front too........
Old 11-02-2009 | 04:34 PM
Doug S's Avatar
Doug S
Golden means too rich, blue is lean. On my EVO, the rear runs a little richer than the front and I do not have any intake leaks. You should check for leaks, adjust the idle mixture and rejet if necessary. How does it run, what do the plugs look like, any black smoke?
Doug
Old 11-03-2009 | 12:06 AM
frenchman's Avatar
frenchman
Nope, no black smoke. Plugs were black before the AC swap. Didn't take them out since. I always thought she runs too rich, a gas mileage of 30 MPG is a pretty good indicator, isn't it? But she runs smooth, no backfiring (neither in the pipes nor in the A/C). I think we can rule out the leaks, the gasket is brand new, and I don't see yet where it is supposed to leak. I may check out the new MPG tomorrow.
Old 11-03-2009 | 06:33 AM
Doug S's Avatar
Doug S
Did you check for leaks where the manifold meets the cylinders, mine was leaking there and still ran fine, runs much better (leaner) after I fixed it and rejetted.
Other than that, sounds like you answered your own question about the rich condition...good luck.
Doug
Old 11-03-2009 | 01:11 PM
Brian_D's Avatar
Brian_D
Do you have pipe shields? There is some stuff out there to help remove the blueing but I can't remember the name. They sell it at the dealer though. I think you'll be hard pressed to find bare exhaust pipes that don't blue to some extent.
Old 11-03-2009 | 04:21 PM
Wallaby's Avatar
Wallaby
All single wall chrome pipes will discolor over time, either get some heat shields to 'mask' the colored pipe, get some double walled style pipes, or get the discolored pipes ceramic coated.
Old 11-03-2009 | 04:40 PM
TW's Avatar
TW
Exactly.
Old 11-03-2009 | 05:01 PM
frenchman's Avatar
frenchman
It's the SE slip on, the fat part where there's no heatshield. Maybe try to make some pichers tommorrow. Thanks guys. Keep it coming, please.
Quick Reply: Pipe colouring
