Raking a Fatboy
Times have changed; at one time, raked trees were only for the suicidal. But the technology has come a long way.
If you want more information on rake and trail, there should be some information in parts unlimited/drag specialties catalogs. At one time, I know there was a chart included in the triple tree section... At least it will give you a reference point as to what to expect in order to maintain frame heighth depending on the stretch (if any) and rake of your frame, the length of your forks and the size of your wheel/tire. [A lot of it's about the Pythagorean Theorem.]
Sill, I believe the best bet is to cut your frame and rake it USING A FRAME JIG and a professional welder.
Done right, the bike should handle just fine, but keep in mind that at first blush, you'll find that at slow speeds, tight turns will seem a little awdward. But, that's the "give." And as they say, "for every action..." The "take" here, is that on straight rides, the bike will ride straight with little effort (if all is lined up correctrly of course). And for highway cruising, there's little to compare.
roll on
-L
roll on
-L
It's no Fatboy but I have a set of 3 degree raked trees on my train... And taking a tight turn is where I feel it the most... Took a few days to get used to but after that no probs.
I did hear though thats raked bearing cups was not a good idea? I wouldn't no though like I said it's just what i've heard?
Nice work!!!
Is it just a matter of putting on the triple trees with the 3 degree rake, or is there more involved???
Maybe something like these? They say sportster but i looked em up under softail.
http://www.realhog.com/detail.cfm?Ca...dson_Sportster
"J" Great looking ride!
Simplified install.
HHI Trees lenghten the existing tubes by about 2". So you remove the existing fork tubes and remove the top caps and install these 2" plugs in there place. The trees come with new bearings and you install as new trees set the pre load etc. The locking hardware is all hidden. So on the plugs are threads they screw into the top tree. Then you install a hidden clamp on the lower tree that tightens and keeps the fork tube tight. You wil need a tube of anti sieze for some parts of the install. The 08-09 don't need an additional fork stiop. Its built into the trees. You also get longer cow bells. The directions where pretty good.
I also lowered my rear by 1" to make up for the front be a little lower now. The draw back is slow driving like in a parking lot is a little tougher other wise no problems
