cam choice
cam choice
I'm trying to figure out what cam to put in this winter... bike ('09 Heritage) is pretty much stock now. Adding a few other goodies this winter, and wondering if anyone can recommend some cams. Anyone know of one that gives a little more high-end? Any help would be great.
thanx
thanx
First of all you need to decide what you want out of a cam. If you want stump pulling low end power you with sacrifice some mid-high end power and visa-versa. Also consider if you plan on doing any future mods. It would be a shame to spend the $$$ on a cam and later have to spend more $$$ when that cam will not work well with the new mods. Is warranty an issue? If so, you will quickly narrow the search. You will get a ton of opinions and many are just that...opinions. Take your time and do the necessary research. Happy Hunting!
need to know more of what U expect and what rpm do U want the TQ at,?
what else are U going to do. ?
What do U mean more high end, speed, rpms, or TQ.?????
Any other motor work planned??
Are U doing a stg1 at the same time..????
what goals do U have, TQ/HP ?????
I spent a couple months reading and learning so I could pick mine.
So if U want us to help U, U need to read and learn a little so U at least know what question to ask to get what U want...
I believe if your going to do just cams and nothing else then you can get just about any bolt in cam for the 96 that has a .550 or less lift. There is a chart out there somewhere so I would do the research and look it up but I am pretty sure of that figure.
For me it's all about having the torque in the lower bands.... not to concerned with top end.
