I got mine off Ebay also from a HD Vegas dealership. $1000. If I were you I would take that If you really wanted it. Worse case scenario is that you can turn around and sell it for maybe more.
Saints, what size tear drops are those on your rear, medium or small? Also, what module do your run to make them turn/run/brake capable?
They are the smaller of the two. I have the Badlands run, brake, turn module. They are bright enough. I might do some red LED strips down the road to go on the swing arm for braking only to give me more. Something hidden maybe.
The sigs are mounted straight to the fender. I can promise Vegas HD ships very quickly. I really do not know how they sell them so cheap. Mine was an opened package with everything in it. I am guessing they put these on bikes and maybe people do not want them on so they turn around and sell them. Thats my guess!!!
thanks for the info. I'm thinking about modding an LED brake light strip to the lip of the rear fender. I might have to fabricate a little metal lip near the end to put over the led light. Something like someone on these forums did on their rocker, but I don't want to go nearly as extravagant. My only worry is not enough brake light in the daytime.
Dale
is that extra metal lip supposed to be welded to the fender ?? and is the LED strip flexible enough to be bend in vertical direction ??
