put the pipes on and U'll be ok,,
only when U add a high flow air cleaner with pipes do U have to add a F/M of some kind..
search this, its only been talked about 1k times a yr for the last 10 yrs.
Alright, I have been told the opposite. Best thing to do is put them and and ride for a while. You will know if it is running good or not.
You will need to have the bike tuned for a pipe change like that. sometimes you can get away with out a tune if you use a slip on muffler that has baffles.
