kuryakan cruiser arm mkIII ?
I tried to install these things yesterday and everything went well untill the tightning of the bolts on the template.The nuts have the plastic washers inside that when you try to tighten they either get stuck that you cant completly tighten and then you cant loosen because their stuck.I ended up breaking 2 of the bolts and drilling out another.What in the world am i doing wrong.I know how to srew in a bolt but this is ridiculus.Is there a technique with this.Would like to know if anyone else has had this problem.Or did i get defective nuts with this.thanks
RE: kuryakan cruiser arm mkIII ?
I installed the same ones on my Fatboy. I believe they are self-locking nuts. They were a bit of a pain to tighten. I wish I would have seen the new Cruise Arms from Kuryakyn (Mark IV) that mount to the frame.
Good Luck. Once you get them on you'll love 'em.
THESE WON'T FIT ON STOCK DELUXE FLOORBOARDS! I learned that lesson. Good thing my Fatboy ridin' buddy wanted an even trade. I ended up cutting the first nut off too. These aren't normal nuts at all. I'm a mechanic and have officially classified them as satan. Spray a lil bit of WD-40 on first. They'll go right on.
ORIGINAL: rick
Well i went today and bought all new bolts and nuts to replace the ones that came with the arms.I went and bought them with locking washers.
ORIGINAL: sfcmo357
I used the two tubes of anti-seize that came in the box. You may have missed the short sentence before the instructions saying to use it.
As for the arms on the bike...I LOVE them! I'm too dang short to put my entire foot on the peg so I just put my heels on the front of the boards and the ball of my feet are on the pegs. It's pretty close to the same foot position as forward controls...only slighty extended.
TexasMotorcycleRider
Milwaukee Eight (M8)
01-02-2019 07:31 AM
