Strange Warranty Issue
Now I don't have a picture because you'd need a really GOOD macro lens to see this.
Everytime I go out on a ride of any distance with varied speeds ranging up to 75mph my chrome oil tank has a bead of oil leading down from the oil filler tube. We're talking about a very small amount of oil.
I've always attributed it to the oil filler cap seeping. Well it seems none of my buddies are having this problem so I looked at the gasket on the filler plug which was perfect with no visible defects.
After todays 140 mile ride the oil streak was once again on the oil tank. This time I looked real close and noticed that there was no oil on the actual filler neck. Hmmm...
I got out a real strong hand held magnifier and in the sunlight there it was. The filler neck base weld had a REALLY small crack in it. I'm sure it was when the welder stopped and pulled off of the bead. I mean this crack is TINY.
Has anyone else ever experienced this?
they replaced my oil tank under warranty, but it did not fix it. it was the rear lower rocker box gasket leaking and blowing back onto the oil tank. To make sure your boxes arent leaking, get a small bright pen light and really look close around the boxes. I couldnt see the leak without the pen light.
Don't ask me how I know this.
1st time I've heard of this one. but anytime a weld is made, that could happen. On the 07's there was a recall on the tanks cause they didn't grind a weld smooth and the battery cable could rub through the insulation and gound out... I had mine fixed but I think all they did was put an extra piece of something over the weld, they didn't replace the tank...
keep us informed on this one...
