Strange Warranty Issue
i haven't seen a leaky oil tank ever (not that it couldnt be that), but believe it or not, the rocker box gasket (if leaking from a small area) can blow against the oil tank in the same place every time. it happened to me on a bike i had 6 years ago. the two most common things that i have seen with oil leaks were the rocker box and the steering neck, although the latter would show signs of oil or grease all over the side of the bike, your pants, oil cleaner...every f'n where..i would like to know if it ends up being the oil tank neck, because generally you dont fill the oil tank up above that area.
I have been noticing a drop of oil on the filler neck tube on my 2010 Heritage. I've been curious what is causing it, but haven't been too concerned yet , thinking that maybe it is just squeezing off the rubber seal when it is inserted, but I will have to check it out further after reading this. Thanks
2010 Heritage Oil Tank Leak
I am having the same issue with my new 2010 Heritage. I have been watching a small stream of oil leaking from the weld at the base of the filler tube and running down across the tank since I took delivery of the bike. It now has 700 miles on it. You can see that it was not properly welded and most of the welding is automated now, so if one is defective, chances are that there are many others out there with the defect in the same area. Check your oil tank. How many more are doing this ?
Dealers taking care of it but the tank never showed up. I got the call from Scott at SuperstitionHD that the tanks are not made by Harley and they really have no control over getting new tanks. I'm going on 2 weeks now but if I had to do this over I'd opt for 'order the freakin tank and when it comes in I'll bring the ride in'.
Scott assured me that the tank would be in Tuesday, that would make it 12 days since I dropped off the bike. I can live with that but if the tank doesn't show Tuesday I'm going to start squeaking.
I've lost 2 weekends already here in Arizona during the VERY BEST weather of the year. I don't think I can take 3 weekends without a protest.
Amazingly the scoot is also in for a new front wheel due to a defect and I thought for sure that was going to be the sticking point on all of this.
Hey Man In Black, that's exactly what my tank was doing. The leak looked like a termite trail leading up to the bottom of the filler tube.
