not the best riding season for me another brake down need help
Sounds like it is time to take it to the HD mechanic. If it is a problem with the injectors not firing, and it appears that this is the case, there should be a code set in the ECM. The dealer should be able to pinpoint the problem for you. I know they are not cheap but just going and buying parts while just hoping you will fix the problem is not cheap either. You could buy some parts that are not needed. An ECM is in the neighborhood of $500. I would want to know for sure before shelling out that kind of bread.
Good luck on this one. Let us know what the problem turns out to be.
redbone62
09-13-2009 02:46 PM
