Starter Issues-Need Help
does any1 have a jackshaft assembled onto their starter? its recomended to me to have one installed. l do have a starter issue. the issue is she starts when she wants to and sometimes grinds. lm planning to have the unit changed out and have a jackshaft installed, too. any feedback would be much appreciated!
mahalo!
mahalo!
Your starter already has a jackshaft.
Sounds like the starter is going bad or there is not enough power getting to the starter. The service manual details electrical checks you can perform to determine if it is the solenoid, starter clutch or other electrical/mechanical issues that are keeping your starter from engaging - electrical grounds, corroded battery cables/connections, broken teeth, etc.
In addition to electrical checks, you will need to pull the primary cover to determine if there are issues with the pinion gear on the starter jackshaft and check the engagement with the ring gear on the clutch basket. Sometimes the starter engagement will either shear the pinion gear or knock teeth out of the ring gear. Could be as easy as cleaning connections to the starter or it could be a $100-500 dollar fix depending on how much they soak you for island prices and shipping for new parts.
The service manual and parts manual for your bike are excellent resources to see how the starter is assembled and how to test it. Having these two manuals will save you from taking it in the okole by da kine dealers when you have issues with your ride.
not to mention 2 maybe 3 guys w/ a shop here on kauai. was also recomended to me to change out the starter. maybe get a 2nd opinion. nobody wants to spend more $$$$ then one needs to. got a couple of friends that know ppl who work outta their homes w/ stuff loke this. *sigh* thanx guys!
ld like to know if there are more stories like mine out there.
Whats up Richie... So does it grind or wine... And what do mean when you say... It's starts when it wants... Does that mean sometimes when you hit the button you get nothing? And you gotta tap, tap, tap the button then the starter ingauges? Contacts and relay will do that sometimes... I had a friend with a fatboy and it would grind and wine sometimes but that was the starter after the starter change he's all good.
I checked the battery and it was 'good' too.
I checked the relay and it was good.
I used an induction amp meter and it showed 250 amps drawn by the starter. (It's supposed to be 150).
A buddy of mine told me that he heard that you should change your battery every three years just as a matter of principal. He also said that a weak battery will eventually ruin the starter.
I replaced the battery instead of listening to what was published in the shop manual. All of my problems went away but I got to my starter earlier in the problem than you have.
To put a jack shaft on your starter and/or to have your starter rebuilt is quite a job. You have to pull the oil tank and the primary.
If you do that, fix the whole thing instead of just doing the jack shaft. You might buy a new starter but if you know a really good starter repair shop you will save some bucks by having it rebuilt, or by rebuilding it yourself (which is shown in the shop manual). You can pull the starter and have a growl test run on it and then decide where to go from there.
C#
C#
