any oil/filter advice please
Old 09-01-2009, 05:32 PM
cammy5477's Avatar
cammy5477
cammy5477 is offline
Default any oil/filter advice please
i am going to change out the engine oil on my xbones to amsoil 20w50 synthetic and have a few questions about it...... i thought i would just change it all out at the same time.... so engine oil/transmission oil/primary oil plus a filter...... can i use amesoil for all or would i be better to use something else in the primary/tranny and what is the best filter to use harley? or something else
can somebody tell me also how much oil each part will need so i can buy the correct amount cause amsoil aint cheap in the uk.
Old 09-01-2009, 05:35 PM
dFREDb's Avatar
dFREDb
dFREDb is offline
You will be very happy with the Amsoil. You can run it in all three, but you may want to research synthetic gear oils for the tranny. Unfortunately, you have opened a can of worms here as you will soon see
Old 09-01-2009, 07:06 PM
jimmers1817's Avatar
jimmers1817
jimmers1817 is offline
I run Mobil vtwin 20-50 syn in mine. Spectro 75-140 6 speed syn in tranny, and HD Formula + in the primary.
2.5 wet fill engine
1qt wet fill primary
1qt wet fill tranny
I'm currently using k&n oil filters but when my case is empty I'm switching back to HD. The HDs filter to 5 microns and I haven't found any evidence that k&ns do a better job.
Old 09-02-2009, 04:47 AM
hpfatboy's Avatar
hpfatboy
hpfatboy is offline
All AMSOIL HERE!!! 20-50 motor, 10-40 primary and 75-90 gear lube, for tranny. Always use the K+N OIL FILTERS, LOVE THE WELDED ON NUT.
Old 09-02-2009, 06:37 AM
aviscomi's Avatar
aviscomi
aviscomi is offline
LOL...here we go again!
Redline all 3 holes
Old 09-02-2009, 07:02 AM
tk353's Avatar
tk353
tk353 is offline
I use Bel Ray for the trans and no wine or clank and I can find neutral. I use Motor Factory® Primary Case Lube in the primary. because Amsoil has gone up so much I just switched to Mobil 1 for vtwin and it works as good. I have 39,000 miles in about 2 years and it runs great and no debris in the oil changes.
http://www.belray.com/consumer/product.fsp?pid=13637
http://www.customchrome.com/dcm/cc/view.asp?mfoil.html
Old 09-02-2009, 10:14 AM
cammy5477's Avatar
cammy5477
2.5 wet fill engine
1qt wet fill tranny
sorry to be retarded but are your measurements from empty?
so once drained i will need stated amounts to get back my fluid levels?
what about oil pressure....if i drain all my fluids at once and then refill how do i get back the oil pressure with out doing damage
Old 09-02-2009, 01:24 PM
jimmers1817
Those measurements are from the 08 Softail Service Manual and yes they're called wet fill specs as opposed to dry such as when the engine is disassembled. Reason being there's a residual amount of fluid left in when you drain it during normal changes.
To help with getting the engine oil pressure back up quickly I partially fill the new filter before putting it on.
You're probably going to need new o-rings for the drain plugs and a gasket for the derby cover (primary). Drain plug for oil is in frame rail directly under oil fill.(do not remove casing plug under the front of the engine) Tranny is between shocks, primary directly under derby cover. All are 5/8 here in the US.
Derby cover requires t-27 torx. Make sure it's seated all the way in the head as they're easy to strip.
If you need torque specs, let me know.
Old 09-02-2009, 02:31 PM
cammy5477's Avatar
cammy5477
great info jimmers thanks man
ohh.... do i need a special release tool for the stock harley filter? im going with k&n for the new one just cause i could get one easy and k&n is good gear
Old 09-02-2009, 03:07 PM
jimmers1817
Just need an oil filter wrench that fits over the end of the filter or a strap type wrench.
Be real careful you don't overtighten the plugs but especially the derby cover screws. Too tight and you might snap them off next time you try to take them out. If you don't have a torque wrench I'd just snug things down and check for leaks.
If you do these are the specs
Drain plugs: 14-21 FT lbs
Derby cover: 84-108 IN. lbs
Quick Reply: any oil/filter advice please
