Rivera 3" belt Drive For HD Rocker
Old 08-30-2009 | 07:41 PM
NO SKOL's Avatar
NO SKOL
3rd Gear
Default Rivera 3" belt Drive For HD Rocker
Any one have the 3" Rivera Belt drive on their 07 later Rocker? I have an 09 SE Springer and it has the blet driver that Rivera makes for the Rocker. I an have some problems with it and wondering if you daily rocker riders are exp the same problem. Every time I drive it, its throwing fluid all over the side of the bike. Im pretty sure it comming from the tranny fluid. I know the Rocker is not a hyd clutch and mind is hyd. I have talked with mike from Rivera and he told me to talk to Ben in the RD department and when I told hime what the issues were and how to correct them he basically told me to F*%^ Off. keep telling me i did something wrong and that I need to check everything. yeah 300 dollars later and still having the same issue. everything from the CVO and the Rocker are all the same part #s that deal with motor and tranny. So if you have one and are having the same issue please post up casue I will be calling the owner tomorrow on this matter. I getting really pissed off and about to just take it off and get my money back. I have put about 200 miles on it and still the same thing. Thanks for any help.
Old 08-30-2009 | 07:45 PM
20NightTrain03's Avatar
20NightTrain03
sounds like you did not use a sealed inner primary bearing
Bigwillie
05-08-2011 07:17 AM
gadawgsfan
01-22-2011 04:34 PM
Ozark Azz
12-22-2010 01:41 PM
timber0472
03-14-2009 09:50 PM
Turbo3pt3
04-30-2008 07:25 PM
Quick Reply: Rivera 3" belt Drive For HD Rocker
