Softail Front Tire - Anyone know?...
Old 08-31-2009, 07:10 AM
John Bernard's Avatar
John Bernard
John Bernard is offline
Originally Posted by WVNightrain Rider
I never liked the look of my 21/90 pizza cutter so I went with the 120/70/21 and a 3.5" rim.
Still not completely happy so this winter I am going to try to find a way to get rid of the lift kit look in the front, maybe a different front end all together.
You say you're still not completely happy... is it because you don't like the look or you don't like the ride? I am fine with the look of the skinnier tire upfront, but the front end seems to be a little light and jumpy for me compared to a Fatboy that I have rode several times. I am hoping to improve that ride a little... will the wheel and tire you mentioned do that? And my last question is, did you have to change to a wider fender when you went with the wider tire and wheel?
I am going to get a set of Reaper wheels anyway this winter, so I want to make sure that I put a wheel and tire on that might feel a bit better to me.
Oh yeah, any pics of your bike with the wider front tire?...
Old 08-31-2009, 07:32 AM
'05Train's Avatar
'05Train
'05Train is offline
Put bluntly, the FX front end sucks. To really get it working better, look at a set of Ricor Intiminators and a good fork brace. The larger tire and wheel will help dramatically.
I'm very happy with the inverted forks I have, but I think I still need to add a brace.
Old 08-31-2009, 11:59 AM
John Bernard
Thanks, I called Ricor up and after speaking to them it sounds like something that will definitely help. However, they did recommend to NOT use a fork brace with their Intiminators. They said the brace will actually work against their product's function, and make the ride too stiff.
As for the wider wheel and tire, are you running them on your Night Train? If so, did you have to go with a wider fender? I'm debating over trying the 120/70/21 sized tire on my stock rim (if that is even recommended), or getting a larger Reaper wheel and then going with a wider tire.
Old 08-31-2009, 12:13 PM
'05Train's Avatar
'05Train
'05Train is offline
I'm running a 120/70VR21 Metzeler ME880 on a 21x3.5" wheel. I'm running a larger Klock Werks fender. I would strongly advise not trying to mount a 120 tire on the stock width wheel. You'll end up bowing the sidewalls out which will seriously compromise handling.
Interesting that Ricor isn't recommending a fork brace. That combination is money on a Sportster.
Old 08-31-2009, 02:08 PM
tk353's Avatar
tk353
tk353 is offline
here is a web site that gives you the original size and other good info
http://www.totalmotorcycle.com/photo...ilStandard.htm
Old 08-31-2009, 03:54 PM
John Bernard
Thanks, I will not upgrade tire width unless I go with a 3.5" wide wheel. Also sounds like a lot of guys on here like the 120/70VR21 Metzeler ME880 on their softails.
Thanks for the link TK. That is a good page to bookmark.
Old 09-01-2009, 07:05 AM
John Bernard
Did you change the fender specifically because the original one didn't work with the new wider wheel and tire, or did you change it for cosmetic reasons? Also, do you have any photos of your bike posted anywhere that show it from the front, so I can see how much wider the new tire and wheel actually look?
Last question is, I have read elsewhere on this forum that a lot of guys feel that the handling of the bike can be improved by decreasing the rake of the front end. They do this by getting it lower as a result of going with a shorter wheel to match the height of the rear wheel. Do you agree with this?
Old 09-02-2009, 08:27 AM
WVNightrain Rider's Avatar
WVNightrain Rider
WVNightrain Rider is offline
The 120 does handle a lot better but not as well has a Fatboy. I am currently using my orginial fender that DOES fit but only with 1/4" clearance.
I think this winter I may change the entire front over to a Fatboy just to get the look I want.
Old 09-02-2009, 06:16 PM
'05Train's Avatar
'05Train
'05Train is offline
I wanted a fender that snugged up to the tire better than the stock one, and I didn't think the stock one would work with the larger wheel/tire. Regardless, I thought it would look silly even if it did work. In hindsight, I do kinda wish I'd gone with a 19" wheel/tire in order to get the bike lower without sacrificing suspension travel. Who knows, I've got a spare rear wheel, I might just sell the set and pony up for a new fender.
Then again, I like the look of the 21 up there, so who knows......
Old 09-02-2009, 09:18 PM
tk353's Avatar
tk353
tk353 is offline
i am going to try a little larger the next time as the 120 wears too fast in a 17 in
Quick Reply: Softail Front Tire - Anyone know?...
