can I use a 11/16 bore master cylinder dual disc with a single disc rotor?
master cylinders on bikes with dual discs are 11/16 bore, master cylinders on bikes with single disc are 9/16 bore, I know it is fiscally possible but what I want to know what is the harm, if any to doing this?
Yeah, but that may not be a bad thing. I'm pretty sure PM recommends an 11/16" bore if you use their differential bore calipers (even on single-disc applications). Assuming you've still got some lever travel, it's just a matter of learning the feel.
