Who makes a good bobbed rear fender for a Night Train with external struts?
Its a milwaukee rear fender, with the built in ecm tray. I had to cut my rear fender horns off, and it bolted right on. After I got it bolted on I took my badlander seat, removed the pading and placed the seat under the frame in the front and taped the rear down on the fender. Then I took a torch or heat gun and reformed the seat pan to fit the aftermarket fender as you heat it use a 2x4 or something to push on the plastic to mold it and hold it there for a second to let it cool to take shape. Then after you get it you can either cut the rear of the pan and pad to have a solo seat or leave it with the pillion pad. The fender is actually shorter than how it came I cut about 6" off of it. Anymore questions let me know, or if you want anymore pics let me know.
If its a harley seat than yea, but you will have to heat the seat pan while everything is off and form it to the new fender. I got mine from J&P, they have with or without the fenders struts.
