Runaway Fatboy
RE: Runaway Fatboy
Okie what kind of tires ya running?are they new?Well any way i was getting wobbles at 65 or 70 and drove me nuts.I bought some new metzlers 880 and no more problems personaly i hate those dunlops
and the solid wheels do affect the ride at higher speeds.The reason i know this is my bro in law has a
heritage almost the same set up as mine and i can take his bike cause in my garage to.Same day i was
riding and was getting blowed around i came home took out his and a it is much better.But i do think
the state or area is some of the problems.Connecticut is a lot rougher than Cali. we get winters here
I ended up buying some fat 50 spokes after the metzlers.Just have not taken any new pics yet.The bike is better than it was with those solids on for me at least.
RE: Runaway Fatboy
I took the Fatboy in tuesday and I had two problems. The neck bearings were tight and had no grease. The dealer greased the bearings and adjusted the fallaway. It is a different machine now. Took to the highway and it was great ! I changed to spokes last winter thinking that would help but a little grease goes a long way! I am going to metzelers after the factory tires wear.
ORIGINAL: 93HD
RE: Runaway Fatboy
Hello to all. I just bought a 05 fat boy with 6000 miles and while gently taking off in 1st gear i get a noticable shake to the bike which is not there if i go harder on the bike. Is this normal since all i had prior is metric bikes and it was not present there. I also have the solid rims and had the chance to ride it in the worst of weather and handled great no problems there. Just wondering if it could be something with the clutch. Thanks in advance.
RE: Runaway Fatboy
Thank you Citoriplus. I noticed that it does handle and sound better at a higher RPM.
RE: Runaway Fatboy
You have to remember that Harley's are low rpm engines. Their red line is far lower than many of the Metric's, hell my old Yamaha had a red line of nearly 13,000 with my Hog its less than half that.
But on the plus side you need nearly 10,000 of those 13,000 rpm's to get anywhere but I rarely need to go much past4,000 to4,500 with the Harley in any gear.
