CrossBones Bars on a Springer
Has anybody installed CrossBones mini apes on a Softail Springer? I am gtting ready to do just that. I will be removing the stock low bad boy style bars on my 04 Springer, and replacing them with the black mini-apes. Does anybody know what overlength cables and brake line I will need to do this swap? Any help and advice would be greatly appreciated.
Go here to find your stock cable lengths:http://www.magnumshielding.com/store/app_search.php
Now do the same for the Bones. Note the difference.
So long as you are running a riser that close to the stock bones risers you will be spot on.
I would just do the Bones lenghts on that 04' even if your riser is a bit shorter. Littel extra cable is always better than tight cables!
04 Softail springer Vs' 09 Bones? Same same.
