Update Front end Shake (Dyna Beads)
Here is how I did it:
1. Placed bike on lift-jack and raised it just enough to take the weight off of the tires.
2. Rotated front (or rear) tire so that the valve stem is at the bottom.
3. Using a valve stem tool, remove the valve.
4. Using the kit that came with my Dyna-Beads, attach bottle containing the beads to the valve stem.
5. Slowly trickle the beads in one or two at a time. As you do this you can speed up. DO NOT JUST POUR THEM IN AS THEY WILL BLOCK UP THE TUBE. Some people will run a dremel or engraving tool next to the vavle stem to shack the bead in. This speeds up the process. It will take all of ten minutes just trickling them in.
6. Once all the beads are in, reinsert the the valve and inflate the tire to recommended pressure.
7. Repeat for other tire.
Once you have completed the above, you should be able to remove your wheel weights.
It is really simple. Hope this helps.
1 Post
Just make sure when ever you check your tire pressure have the valve stem at 12, 3 or 9 oclock if you have tire turned with the stem down at the bottom when you check pressure the dyna beads can get stuck in the valve and cause a slow leak. We've used dyna beads for the last 6 yrs in all of our bikes
