Converting EFI tank to a carb model?
I have the same deal. I did get new tin that was an EFI style but is marked Carb on the top plate. It has a petcock. However there is a plug on the top plate as well which I dont know what it goes to. Assuming it is to a sending unit. The gauge tube is not like my 01 so i also assume its for a digital style. What gage would work.
My bike is an 01 Heritage Softail and had not plate on the tank. I am assuming this newer tank should work but figuring out the fuel gage is an issue.
Interesting...
I too, believed that the EFI softail bikes had the large removable panel in the center of the tank, for the EFI pump and fuel gauge float assembly....
I also believed that all the Carb model bikes, had only the hole under the faux gas cap, where the fuel gauge float assembly mounts....
But then I also found this float assembly, that has no fuel pump, and that mounts through the center panel of what I thought were only EFI tanks....?!?!?
So it looks like it's for a Carb bike...?!?! I have an "01 Springer Carb, and an "03 Heritage EFI that both follow what I previously thought was the rule...
My best guess, after a quick parts search (it was a quick search so don't take this for gospel)... it looks like in 2004... the softails all used the tank with the removable, large center plate that mounted either the carb fuel sending unit, or the EFI pump/fuel sending unit... It even showed two different top plates for that large center hole, depending on fuel delivery choice...
I know this is an old thread and the OP is long gone, but I just did a quick search to find this info, because the posted pic made me curious...
dlowder
Exhaust System Topics
09-11-2007 09:45 AM
dlowder
General Topics/Tech Tips
09-11-2007 03:18 AM
adapter, bike, carb, carborated, change, convert, converting, efi, fuel, harley, injected, plate, put, replacement, tank
