FXST Front end clonk
I had the exact same issue on my Night Train and it started around 1000Km.Anytime I hit anything that resembled a bump it made this noise. The Dealer checked the front end, tightened the steering head bearing,they dropped my fork oil and fully inspected my front fork tubes with no avail.One night I was in the garage looking at the bike and I started thinking about removing the front fender like some guys have done to see if I liked the look. Long story short, I liked the look but I didn't like a face full of spray when hitting any wet stuff so I put the fender back on. The very next time I went riding I noticed the clunk but more importantly I realized it didn't happen when the fender was off. I'm thinking that somehow it's transmitting vibration or moving around when the forks are compressing. I put some rubber washers between the fender bracket and the forks and the noise is gone, so far so good.
On my 07 fxstc , it was the bucket of the headlight hitting the bracket inside. A hit on the top of the headlight with your hand will duplicate the sound. Had to cut 1/4" off the bracket to give more room for the rubber mounts to move. Second source was the stock fuel cap. Changed that to kury flush mount. No more front end noises.
Ron
Ron
I had exactly the same sound. I could feel it in the steering.
Two problems. Both are mentioned above
1. Steering head was loose. Took my dealer 5 minutes to fix it by tightening the steering head.
2. The headlight is rubber mounted and would bottom out on a hard bump. I tightened the bolts down inside the headlight housing and compressed the rubber washers pretty tight. Keeps the light from vibrating at night when riding also.
After doing both of these things, I have to really hit a hard bump before I feel or hear anything. It can be fixed--see a decent mechanic/technician and they will fix this quickly by tightening the steering head and getting the slop out of it. All you have to do to check this is to roll the bike forward slowly and grab a hand full of front brake. If its loose it will clunk.
I had one dealer tell me the headlamp was not rubber mounted--didn't know what they were talking about. In the 2007 FXSTC, they rubber mounted the headlamp. Some techs do not keep up with the latest changes and will try to BS their way through trouble. @#$%^&
