Front forks leaking from cap nuts
Old 07-27-2009 | 05:51 AM
dbleagle's Avatar
dbleagle
A layer of teflon tape worked for me... been about 8 or 10 months and no leaks...
Charlie D.
Old 07-28-2009 | 01:40 AM
JayDee5150's Avatar
JayDee5150
Ok...i've pooled all the advice you all have left me...and I will put it into practice this weekend (time permitting).
Old 07-30-2009 | 10:16 AM
JayDee5150's Avatar
JayDee5150
Ok...had some time to check the forks and sure enough...the fork tube plugs were both loose...not finger loose...but at least 2 turns loose.
I went ahead and dropped the forks down a couple of inches so I could get at the plugs with a wrench. Tightened up the pinch bolds to hold the tubes in place...and got about a quarter turn tighter on the right and almost one and a half turns on the left (left side was leaking a lot more than right).
Hopefully that seals the deal...so to speak...with this deal!
I'll let you guys know after a good ride this weekend..
J
Old 07-30-2009 | 11:01 AM
tlb's Avatar
tlb
isn't it a amazing how these could be lose? hope it solved your problem.
Travis
J
Old 07-30-2009 | 04:23 PM
dkyork's Avatar
dkyork
J
Interesting, I wonder if they were like that initially. I thought the Fork Cap bolts held the fork tube nut still and the pinch bolts stop the fork tube from turning. You probably won't have any issues anymore if you tightened them all up now. Good luck.
Dale
Old 08-03-2009 | 05:50 PM
JayDee5150's Avatar
JayDee5150
Well...took the bike out for a 100 mile trip last weekend and so far no leaks...knock on wood...looks like that fixed it.
Thanks for your help guys!
Old 08-03-2009 | 06:01 PM
tlb's Avatar
tlb
good deal, hard to believe those can work their way loose.
pgilbert689
06-30-2018 08:30 PM
Ozark Joe
EVO
54
01-15-2017 07:36 AM
O-Town D
03-03-2011 04:35 PM
crepe
08-20-2008 02:26 AM
DGlide04
06-13-2007 01:33 AM
