09 Fatboy steering shake
Old 07-21-2009 | 09:53 PM
jed1069's Avatar
jed1069
Default 09 Fatboy steering shake
Just returned from a long trip with quite a bit of highway travel. I noticed at speeds between 75-80 frontend felt like it had speed wobbles. It was not a typical unbalanced wheel shake. I was just wondering if this is common on fatboys because of the steep steering angle. Any suggestions are much appreciated.
By the way stock tires with 2500 miles on them running 37 lbs of pressure.
Old 07-21-2009 | 09:54 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Sponsor
Tire pressure or steering head bearing tightness.
__________________
Old 07-21-2009 | 10:04 PM
BigBaldAl's Avatar
BigBaldAl
5th Gear
Relax, sometimes if your grip is too tight you will transfer the movement into the front end.
Old 07-21-2009 | 10:07 PM
bgh4hrlyd's Avatar
bgh4hrlyd
Not sure how that works, but it does. Sometimes just letting your arms and grip go limp will stop that wobble. Guess sometimes you tend to fight and counter from side to side, but, Id still have it checked out, could be bearings in the neck
Old 07-21-2009 | 10:22 PM
jed1069's Avatar
jed1069
Guess I will check the head bolt tomorrow had not thought of that yet. As far as grip goes I tried very loose grip and one hand as well no change at all but good thought.
Old 07-21-2009 | 10:23 PM
Red9's Avatar
Red9
Also I have noticed how I have the bike loaded with gear or a combination of passenger and gear can cause the shakes.
My suggestion would be to ride the bike again at speed with just yourself on it and see what happens.
Lee
Old 07-21-2009 | 10:28 PM
jed1069's Avatar
jed1069
I was riding solo with no luggage. I'm thinking it most likely is headbolt tightness.
Old 07-21-2009 | 10:54 PM
GunmetalBlueNT's Avatar
GunmetalBlueNT
check the steering neck fall away, could be a bit loose. You could have also thrown a balance weight too, or could have a small nail in the tire, check those issues as well. Could even just need to rebalance the tire as well. As for tire pressure,, shouldnt it be in the 40-45lb range?
Old 07-21-2009 | 11:06 PM
kccustom's Avatar
kccustom
Was it windy? Mine does that sometimes when its windy out.
Old 07-22-2009 | 12:30 AM
oct1949's Avatar
oct1949
not normal, If can't get it corrected, just take it in...
