Most Quiet Baffles
Anyone tried those: http://www.smartpartz.com/baffles.html
they seem to do their job but I can't find any answer in our forum...
The V&H Big Radius pipes add 15-20 db according to V&H. That is a ton. Look at the disclimers on the aftermarket exhausts. All say something like "for off road use only". I love the Big Radius pipes on the Rocker but don't want the noise. The after market baffles for the Big Radius are very short. Can't immagine that they do much unless they block the air flow a bunch.
It's all about tradeoffs. If you want more power you're going to make more noise. If you want quiet, you give up power. Simple physics, laws that can't be repealed.
I just bought the V&H Bigshots Staggered for my 2001 Softail Springer.
What are the best / quietest baffles that will work with these pipes? Do the V&H quiet baffles make a huge difference?
Although they sound awsome, I need to tone them down a lot or I'm in for many a ticket since in Montreal we're not even supposed to have baffled pipes.
It's still got some rumble to it for sure, but it's a really DEEP rumble rather than a blatty rumble if that makes sense. Definitely quieter and sounded 10x better in my opinion.
I too have been leaning towards changing the baffles in my BSS. Hammer's description of a "blatty" sound is exactly what I am looking to change. I am down to a choice between the V&H QB's or the Big City Thunder baffles. They have one to fit the 2" ID of the BSS. Been reading good things about them too.
EDIT: Sorry about the double post. I'm getting old. I forget things. Forum mods, feel free to delete.
I just installed v & h bss a little on the loud side and seems a little flat in the lower rpm range talked with jim at big city thunder and ordered a set of the qb baffles he said it would help with the flat spot and give the pipes a much deeper tone.
Maybe I just wasted some money but I get them thursday and I'll get back with results. Have a doherty intake ordered too. Guess I'll have to get it remapped after these changes and see what the final results are.
95" 251 cams 10.25 84hp 93 t before pipe and intake change
