Best Oil Cooler
Old 09-13-2018, 08:10 AM
tmac00333's Avatar
tmac00333
tmac00333 is offline
Received 1,807 Likes on 1,174 Posts
Originally Posted by 128auto
+1 exactly
That's why I switched to amsoil for the same reason, it runs cooler, never hit 250 in traffic, even the hottest day here.
I use synthetic and I hit 250 and over all the time and I rarely ride in traffic.
Old 09-13-2018, 08:16 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
HDs fan assisted oil cooler at lease for the newer Bikes they work great.
Old 09-13-2018, 08:26 AM
cdonis's Avatar
cdonis
cdonis is offline
Ultracool 2.0
Old 09-13-2018, 02:22 PM
txphatboy's Avatar
txphatboy
txphatboy is offline
Originally Posted by hotrod351
my bike came with the stock HD oil cooler, even in 100 degree temps and sitting for a while i wont get much over 160 - 180 degrees. oh yeah, im here in arizona where temps start out in the morning at 100 + and will hit 120 degrees.
Where and how are you measuring engine temps? 160-180 F are really low temps, especially in 100+ F weather.
Old 09-13-2018, 02:26 PM
TUFF LUCK's Avatar
TUFF LUCK
TUFF LUCK is offline
Originally Posted by George C
You can lower your temps around 10 degrees using an oil cooler. Basically useless and ugly to look at, not to mention having the need for external oil lines that could be damaged easily. You can gain almost 150 degrees of protection just by using a full SYN oil. There will never be a need to use an oil cooler, even in the hottest days in stand still traffic temps if you use a full SYN..
yup I run Amsoil on everything. Bike, trucks he’ll even use the small engine Amsoil in my lawn mowers
Old 09-13-2018, 07:06 PM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Received 10,871 Likes on 4,114 Posts
Originally Posted by Milan
My fan kit will keep your motor cool in traffic. The fans are water and dust proof and move alot of air. Right now I'm having a Sturgis sale , 15% off.
Milan
Originally Posted by htoler
and what fan kit would that be ?
I'm fairly confident you won't receive a reply from Milan. He posted that comment in 2009 and hasn't been on the forum since.
I wonder if oil coolers have improved since this thread was started nine years ago? For completeness sake, I have the Wimmer twin tube oil cooler.
Old 09-14-2018, 11:08 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 5,075 Likes on 3,451 Posts
Most oils start thermal break down at 280*. If your consistently running 250* and above I would seriously consider looking at your tune.. might be a bit lean or even to much timing... Also a 10 row Jagg will lower oil temps 35* (moving)...
Old 09-16-2018, 11:06 PM
breakman's Avatar
breakman
breakman is offline
Received 1,553 Likes on 1,216 Posts
Here is my Jagg oil cooler on my Breakout. It is barely noticeable with the black fittings and hose.
Old 09-17-2018, 05:12 AM
Bluraven's Avatar
Bluraven
Bluraven is offline
+1 on UltraCool.
From what I can tell it keeps my oil around 220-230 in the worst case.
IMO- the time an oil cooler is most beneficial is in stop and go traffic.
So if you have one without cooling fans I'm not sure the oil cooler is that effective at least when you're not moving that much.
Old 09-17-2018, 04:31 PM
breakman's Avatar
breakman
breakman is offline
Ultracool does not have a oil cooler for Breakout with ABS.
Quick Reply: Best Oil Cooler
