Cost of the 103?
I'm in Australia and when I need parts I'm straight onto the Chicago Harley Davidson website
http://www.chicagoharley.com/shop/
- 20% off and great guys there who will help out (George is a champion)
Stage 4 - SE 103" under 2K !!
Here's a couple of links to some top notch kit makers:
http://www.tmanperformance.com/
http://www.zippersperformance.com/default.asp
Essentially if you're on a budget the same dough spent on a set of big jugs and pistons would gain you more bang for your buck if said monies were spent on your current 96".
A spiced up 96" with worked over heads, additional compression via honed cylinders with hand matched rings, 5 angle valve seat grind, good cams, good exhuast, and a good solid tune can make around 1 HP per cubic inch and 1.1 Lbs Tq.
Or essentially a 96" with 90-96HP/108-115Lbs Tq build thats a reliable daily rider and not all that pricey.
