Just Pipes?
Pipes only ok.
Piped and AC, then need FM.
with the pipes only, U'll still be running EPA lean, the same F/R as stock, only louder.
Website is kinda of low end but their product is top notch. Check them out as well as search this forum for them. Many of us use them and love them.
http://www.nightrider.com/parts/
As far as getting the FM's that others have stated... Do your research if you are not going nuts with the performance mods the XiED should work for you. Newer HD have a pretty smart EFI. The XiED works for me and it cost way less then a tuner... that's my 2 cents That said, I always keep an eye on my plugs just to make sure I am not running to lean or rich.
Good Luck
vandykemc
03-24-2008 12:16 PM
