56269-09 HARLEY DAVIDSON Curved Pullback Riser
Old 08-22-2009, 09:00 PM
soph9's Avatar
soph9
soph9 is offline
Looking forward to adding them...should make my riding position just right and if it doesn't...well I will take them back...I wasn't sure how you did the break cable but i will try what you said...they sure do not leave you too much room with that one cable...BTW...I just added RJS heat deflectors...takes the heat off the thighs. My oil tank was exposed due to my Corbin narrower seat...was getting blisters and hated my bike...these little deflectors work like magic....just some info!
Old 08-22-2009, 10:59 PM
soph9's Avatar
soph9
soph9 is offline
Got another question....will my stock '09 handle bars fit this model riser? 56269-09?????
Old 08-23-2009, 06:12 AM
soph9's Avatar
soph9
soph9 is offline
ok...I think my stock bars are 1 inch so therefore unless I change my handle bars these riser will not fit....I think I will wait....
Old 08-23-2009, 09:03 AM
SlowPlay's Avatar
SlowPlay
SlowPlay is offline
stock FAT BOY bars,starting with the 2007 models,are 1 1/4" in diameter. these bars do NOT reduce down to 1" at the risers(the clamping area). p&a risers 56267-09 and 56269-09 are for use with 1 1/4" dia bars,H-D or aftermarket (that do NOT reduce down to 1"). see page 596 of 2010 p&a. hole through riser clamping area is 1 1/4 dia.
Old 08-23-2009, 09:23 AM
soph9's Avatar
soph9
soph9 is offline
OK....then my handle bars would fit this riser....thanks for the info!
Fozzy4325
Classic HDF Photos
01-25-2014 09:10 PM
SMF
02-18-2011 08:16 AM
captainjack
11-24-2010 09:09 AM
Matrix
04-22-2008 09:54 PM
Quick Reply: 56269-09 HARLEY DAVIDSON Curved Pullback Riser
