Risers and bushings for Wild1 apes help!!!
Alright I'm in the middle of the ape hanger install and just ran into a huge setback...
I have the Wild1 bars and 1.5" risers. I never purchased the clamp because I thought I can use the stock HD clamp. So...are there 1.5-2" risers I can purchase at the dealer that will work with the Wild1 apes and stock clamp?
Second...I purchased the poly bushings, but how do I take the old ones off and install the new ones? Need a press? Will probably stick with the stock ones then.
Was planning on riding tomorrow, but it looks like it's not going to happen.
Thanks,
Dave
Thanks,
Dave
As far as the risers go I should have clarified that they are 1.5" tall and not for 1.5" bars. The bars are stepped down to fit the stock clamp, but the problem is that the bolt pattern on the Wild1 risers do not line up with the stock clamp.
Well to complete the installation I will use the stock Deluxe risers and clamp even though the risers are huge and bent forward.
drspencer
12-13-2012 11:41 PM
