Floorboards forward?
1 Post
the quickest and (maybe) the cheapest way is to install HD # 50409-04 ERGONOMIC OPERATOR FOOTBOARD KIT" ... just HDs way of saying extended floorpans for touring bikes.
they do fit a Fat Boy - they're on my '08. took all of 15 minutes to change.... wouldn't have taken that long, but I couldn't get the rubber insert out of the stockers...... finally used liquid dishwashing detergent (like the instructions said) and they just popped out.
I copied Sonar Chris - from the extended floorpans, the Harley Goodies, extended gear shift lever and an extended brake pedal lever.
seems like they were about $60 for the set.
1 Post
Got the new pans today, and once I removed the rubber board, it was obvious it wasn't going to work for me. The holes in the reinforcing plate from the Mark IIIs don't line up like they do on the stock pans.
I thought about just drilling new holes in the plate, but that would mean going through the support brackets on the pans, so that's a non-starter. I could also have tried to move the Mark IIIs backward, but there is a 'hump' on the underside of the pan that's in the way.
Bottom line, the HD 50409-04 ERGONOMIC OPERATOR FOOTBOARD KIT will NOT work WITH Kuryakyn Cruise Arm Mark IIIs. They WILL work without em, but I like the Mark IIIs so I just hope not to get raped by Hot Rod HD when I return the floor pans.
sorry they don't work for you... must have something to do with your bike being an '07 and mine an '08.... guess HD changed the layout of the pans or something???
if you'll go back and read Chris' recount of how he installed them, you will need to drill a couple of holes - but, that's no big deal.
