Hit a bump and my handlebars...
Old 06-21-2009, 08:35 PM
CrossbonesTed's Avatar
CrossbonesTed
CrossbonesTed is offline
Default Hit a bump and my handlebars...
almost folded flat against the tank. Is this normal? My bike has about 750 miles on it.
Old 06-21-2009, 08:42 PM
firedocs's Avatar
firedocs
firedocs is offline
Default Bars
Uh.....NO not good. Probably just need to tighten the four bolts on the bars at the top of the tree. Get them back where they feel right and tighten down in slow increments for all of them.
Not too hard..as long as you have the right wrenches.
Old 06-21-2009, 08:48 PM
m i k e's Avatar
m i k e
m i k e is offline
1st off b4 you tighten them get owners manual,loctite(red)
torque wrench and follow steps to re tighten those bad boys down
total bummer dude thank GOD your ok that is a huge SCREW up on moco/dealer
someone probably has order/ft.lbs
Old 06-21-2009, 08:57 PM
tripwire759's Avatar
tripwire759
tripwire759 is offline
Dude that could have been ugly. I would at least call the dealer and yell at the Service Manager about the guy who did the set up. You might get something out of it.
Old 06-21-2009, 09:09 PM
Xuallus's Avatar
Xuallus
Xuallus is offline
careful not to over tighten, the risers are aluminum and strip out pretty easily... don't ask how I know
Old 06-21-2009, 09:39 PM
m i k e's Avatar
m i k e
m i k e is offline
+1 b4 you get delivery the bars are off
1 more nightmare dealer story
Old 06-21-2009, 09:46 PM
Cheesecake's Avatar
Cheesecake
Cheesecake is offline
IMO it's a common occurrence with the XB...
the risers don't grip the powder coated bars very well....
there are several DIY fixes... sand paper or aluminum can wrapped around bars under the riser clamps... using a chisel to texture the bars... and I'm sure there are others...
be careful tightening up the riser bolts... as Xuallus stated they are easy to strip out!
krwould's Avatar
krwould
krwould is offline
Received 1,313 Likes on 1,028 Posts
Don't hang on so tight!!! Just kiddin... nope this is not normal!!! Torque wrench and some loctite like another said before!!!
Old 06-21-2009, 10:18 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,949 Likes on 1,933 Posts
You can also use emery cloth as opposed to aluminum cans. People that I know that have apes have this happen every once in a while, but never all the way back to the tank. Watch out for those bumps.
__________________
Old 06-21-2009, 11:12 PM
oct1949's Avatar
oct1949
oct1949 is offline
No not normal...
I Can't believe Some of the questions we get!!!!!
Quick Reply: Hit a bump and my handlebars...
