Installed new tri-bar tail light
Old 02-11-2012, 03:02 AM
drspencer's Avatar
drspencer
drspencer is offline
When using the Tri-Bar, can people behind you easily see you brake during the day?
Is the Tri-Bar more or less bright than stock?
Thanks
Old 02-11-2012, 07:01 AM
Hollywood Ball's Avatar
Hollywood Ball
Hollywood Ball is offline
Thanks
Definitely brighter, IMO.
Old 02-11-2012, 09:06 AM
Scheers44's Avatar
Scheers44
Scheers44 is offline
Yeah it's more visible for sure. Nice upgrade IMO.
Old 02-11-2012, 11:16 AM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
Not the best pics, it tends to screw up the cameras photo sensor, but its what I got.
Running lights on in the garage.
And with the Brake light on;
Guys who have been behind me tell me its damn near too bright.
But it does get your attention and that's the important part as far as I'm concerned.
Funny thing is that since I converted the turn signals to brake/turn functions and installed LED bulbs the back of the bike looks like a cop car or fire truck when I hit the brakes.
Somehow I screwed something up or messed up the logic circuits in the HD run/brake/turn module when I changed the wiring in it to turn/brake only and now if I'm stopped with a turn signal on.
The Tri-Bar and one turn signal blink while the other turn stays off.
If I put the brakes on the Tri-Bar and one turn stays on bright while the turning side blinks.
Its not 'supposed' to work that way, but I think I like it better as its a lot more visible in day light.
Old 02-11-2012, 06:00 PM
Wide_Open's Avatar
Wide_Open
Wide_Open is offline
I agree it's much brighter and a definite improvement.
Old 02-11-2012, 07:50 PM
cb133's Avatar
cb133
cb133 is offline
6th Gear
How much work is it to make the tri bar tail light not only function as brake lights but turn signals as well?
Old 02-11-2012, 09:49 PM
Forget it unless you have access to an electronics lab to rewire it and add the electronic parts (chip's) needed to do the job.
I haven't taken one apart (its way too damn expensive to experiment on) but if I had to guess once you got it open all you would find is a circuit board full of LED's and the load resistors needed to operate them.
Old 02-12-2012, 07:28 AM
Joker_Hal's Avatar
Joker_Hal
Joker_Hal is offline
I like the look of that new tail light. A big improvement over the stock lights. Should come standard on all bikes.
Old 02-19-2012, 08:14 PM
mazeone's Avatar
mazeone
mazeone is offline
Stage II
Originally Posted by jd8181
i can't find one for my 03 train. everything i see is for 06 and later (200 rear tire) anyone see then for pre 06. i've been wanting one but haven't been able to find one.
I know this post is over 2 years old but I have an 02 Train I want to get one for. You ever get the tri or something else?
Old 02-19-2012, 09:22 PM
mac1911's Avatar
mac1911
mac1911 is offline
Looks great and much more visible.
Quick Reply: Installed new tri-bar tail light
